How can scouters see if a power cell goes to Outer\Inner Port
Assuming that I don’t want to dedicate scouters behind each Power Port,
you don’t have a very clear sight line to see to where the balls goes to.
Anyone had a suggestion how (without adding more scouters) the scouters can see that?
*After We’ll attend our first event, I might understand that in a specific seating location it wouldn’t be a problem at all… but I’m trying to see if I can figure it out before the event.
There have been two threads posted about this already:
You can either move to the side the robot you’re scouting will shoot into, or you can look at the score, and see how many points are added. Checking the scoreboard requires more attention, because there’s more than one robot contributing, but both are viable options for scouting.
As you said, points on scoreboards can updated from different points simultaneously (and also require the scouter to move his eyes from the robot he scouts).
Thanks @Squirrel2412,
I don’t like the sitting spots suggested in those threads (altough they might solve one problem, they might create a few others). Hope to find a different solution.
Nothing wrong with finding a different solution…but in the name of thread hygeine, let’s find that solution in one of the two existing threads. :slight_smile:
