I am guessing your team used the kit of parts chassis.
Here is the calculations that go into figuring the theoretical speed of the robot. This is purely theoretical, as previously stated, this speed is when the motors generate 0 torque so this is unattainable. Though this is the number most teams use to compare drivetrains.
6" Diameter Wheels
Toughbox Mini 10.71:1 Ratio
14/50 1st Stage Gearing 3.57:1
16/48 2nd Stage Gearing 3:1
3.57x3=10.71:1 overall ratio
4 CIM Motors
6" wheel=Wheel Diameter * Pi=6*3.1416
18.84" traveled per revolution of the wheel
18.84" / 10.71 * 5310 rev * 1 minute * 1 ft
1 rev 1 1 minute 60 secs 12"
= 12.97 feet/second
The actual speed can vary drastically due to power losses through the drive train system. This can vary due to wheel type, efficiency losses due to additional stages of gearing, bad gear mesh, too much tension in the belts or chains, just to name a few. Weight of the robot will also effect this value.
We were at 70% of our theoretical speed last year.
If your drivetrain losses were similar this year, this puts you at around 9.0 feet/second actual surface speed across the floor.
For reference we were at 13 feet/second actual surface speed last year.
This means we would have covered 1.5x more ground than you at full speed.
You can measure your actual speed by making two lines on the ground at a known distance, we use 20 ft between marks. Get the robot up to full speed before the first line and measure the time it takes the robot to travel the 20 feet between the two lines you have on the floor. Have multiple people do the timing, do multiple runs with your robot, throw out any values that are outside the norm and average your results between the good values. Then you can calculate the feet per second by dividing the distance and time.
20ft/2seconds=10 feet per second
Then you can divide your actual speed by the theoretical speed to get the percentage difference.
9ft/second (actual) / 12.97 feet/second (theoretical)
71% actual to theoretical
This can be used for future reference.
This all negates acceleration times for simplification.
For example, most teams do not exceed 20 feet/second theoretical speed.
Anything above 20ft/sec consumes more current to get the robot accelerating and slows the acceleration of the robot to a point where the top speed advantage is negated.
I hope this helps rookie teams learn a little.
