How did you do OTF Trajectories
We never fully got on the fly trajectories working with path planner. Though we did get direct line to Pose navigation with a PID. I don’t have access to the bot now to work on it. So I was curious if any of you who used PathPlanner to make on the fly trajectories care to share your code?
Did you generate the trajectory on a button press or were you continuously generating in the back ground?
Did you use logic to determine different way points based on the position in the field?
We did use the PP libraries to generate OTF trajectories, although they are only straight lines. I imagine you could add some more waypoints to get curves.
You can find the code here:
You want to look in commands/TagPositionDrive.java in initialize(). That creates the trajectory, and then hands it to subsystem/Drivetrain.java makeFollowTrajectoryCommand() to create a command.
If you want OTF trajectories that avoid obstacles we used A* with a lot of path gen control after that, lets you go from anywhere to anywhere else and make your paths on the fly,
Auto-scoring with Dynamic Pathfinding and Inverse Kinematics - Technical / Programming - Chief Delphi
Pathfinding On The Fly with a 3d Field - FIRST / Robot Showcase - Chief Delphi
We just released 3061-lib with this season’s code, which includes a MoveToPose command and associated classes that generate paths on the fly. The path generation was triggered on a button press. The field was modeled as a collection of regions with transition points defined from a region to each of its neighbors. The path was generated to pass through these points between the starting and ending points.
The MoveToPose command class is a good place to start with more details in the Field2d and Region2d classes.
