In Kevins codes how do I do that?
tnx ahead.
tnx ahead.
Look in gyro.h. There’s an option to change the analog input that the gyro is connected to.
When I do that, I am not able to get any signal.
And what about the Accelerometer?
Open up adc.h and define the number of channels you want the software to cycle through. The channels must be consecutive and always start at channel 1. Then you can assign the gyro to one of those enabled ADC channels.
-Kevin
Did that (anabled another 2 analog chanenls) and consequently the Gyro won’t give me any accurate values. I guess it’s because of the change in the sample rates.
What else can I do ? Change some other definitions?
Most likely, you’ll need to double your sampling rate. Make sure your system can handle this higher interrupt rate before doing it, interrupt timing issues are very difficult to debug once they crop up.
-q
This expression, from adc_readme.txt, will allow you to calculate the update rate:
Update Rate = Sample Rate / (Samples Per Update * Number Of Channels)
If you are sampling three ADC channels and left the other settings at the default, you’re only getting ~17 updates per second, which is pretty low. You’ll want to bump this up to somewhere in the 50-100 updates per second range by raising the sample rate and/or lowering the number of samples per update. For grins, try changing the sample rate to 1600Hz and change the samples per update to 8 and see if it’s any better.
-Kevin
yup works perfect.
A new question came up - if will increase the opened analog channels by another 2 (for example), I’ll have to do this actions again?
