So between,
Spark Firmware, Talon Firmware, PDP/PCM Firmware, Roborio OS, WPIlib update, limelight update, etc.
whats the best way y’all have for keeping everything update when an update is made?
So between,
A nice spreadsheet, once you set it up, is relatively easy to maintain. When you hear about an update, note it on the sheet, check the sheet periodically, record updates you have made to the sheet once you make them, etc.
It’s dizzying, so I certainly wouldn’t try to just keep track of it mentally.
And then, a labelmaker with the details on the side of the unit (say, firmware and CAN ID) so the one you forgot and the freshman pulled out a week later can be identified.
