I’ve been a little confused how you can retrieve the hatch from the loading station. Do you have to lift up the hatch or pull it or something? The technical video didn’t give a good demonstration of the process. If there’s a video of it being used, can someone post it? It’d be a big help thanks!
It’s held in by brushes. Pulling on it would suffice.
It is dropped in at the top and rolls down, there it is held in place with brushes. You can pull it out rather easily, after the reveal they demonstrated that a pinky finger is enough
Ah ok thanks! Just wanted to make sure
How much front to back play is there when the hatch has been dropped into the station?
