How does wpilib framework handle .andThen
We have the following command in a ParallelRaceGroup
new WaitUntilStable(m_limelight::getDistance, 0.01, 10).withTimeout(1).andThen(m_limelight::snapshotDistance)
So m_limelight is extend from CommandBase.
Once the command is running, each loop of the wpilib framework will call the following…
Execute
Is Finished
(if finished returns true) End
My question is will the “.andThen” execute in the immediately after End, or will it wait until the next 20ms cycle?
Thanks
andThen forms a sequential command group. When the previous command ends, end will be called, then the next command will be initialized in the same loop. The next commands execute won’t be called until the next cycle.
https://first.wpi.edu/wpilib/allwpilib/docs/release/java/src-html/edu/wpi/first/wpilibj2/command/SequentialCommandGroup.html#line.59
