I can type 39 wpm with a 94% accuracy according to the following test.
3 minutes Wizard of Oz http://www.typingtest.com/default.asp
Take this test and see how fast you are. Use the same settings for uniformity and post your results here.
I used to be able to type 75 wpm on a standard manual typewriter, with only 2 mistakes during (I think) a 2 minute test. Back then we had to erase our mistakes, line up the paper again, and retype the letter. Computers used punch cards, so if you made a mistake programming, it usually meant punching a replacement card.
I don’t run java on my computer, so I can’t take the test you linked too…but I could get out one of the old typewriters and see how sorry I am now that I have a backspace key
68 wpm at 94% accuracy.
Know I’ve done a bit better on a similar test though.
70 WPM 97%
Once upon a time long long I was able to hit 100
I used this one
http://www.typeonline.co.uk/typingspeed.php
and got 73 and 80 wpm with 4 mistakes each time.
edit: I’m using an IBM keyboard made in 1992
Highest I recall ever getting was something like 120 - 130 wpm, albeit with liberal use of the backspace key. I took the Oz test you linked to and managed 50 wpm with 96% accuracy. To be fair, I am typing on my Dell mini 9, an 8.9 inch netbook.
89 WPM, 95% accuracy… could be better…
Wiz:
Try #2 84 wpm net; 87 wpm 95% accuracy
Try #3 95 wpm net; 102 wpm 93% accuracy
Could probably do better if not sitting here on the sofa with the laptop.
I used the same one; 92 words per minute with no mistakes. I enjoy the ability to use my backspace key.
Now I just have to increase that to my maximum rate of speech… (250-300 wpm, thank you debate)
Ehh I only typed at 45 wpm with 95% accuracy. Of course if I didn’t have to type what they wanted me to then I would be able to type much faster. Like essays and things that are in my own words I can type much faster.
On that test, 67 wpm, 97% accuracy.
It depends what I’m doing though- I can tell I’m typing much faster right now because I don’t have to look at the screen to read exactly what I have to type as I’m typing it, I can just put down whatever it is that I want to say. Similarly, I type much more slowly when I’m retyping information, such as off of a paper, or the passage on the typing test. I also type more slowly on unfamiliar keyboards, as my fingers end up hitting the wrong keys much more frequently. (:
On The Wizard of Oz test, I managed 102 wpm @ 94% accuracy.
Net Speed: 52 WPM
(words/minute)
Accuracy: 83%
Gross Speed: 63 WPM
(words/minute)
118 wpm with 92% accuracy. It’s a slow day.
(I’ve always been known for quick typing, and speed talking.)
71 wpm, 86 percent accuracy… but hey, that’s wat spell check is for… right?
