How Many Iterations?
Hi,
How many iterations per second does “Iterative Robot” method do for periodic functions?
Are they constant? Or are they variable?
THANKS!!!
-Masoug
By default the period is whenever a packet is recieved from the DS (about 50 Hz according to the source).
To define your own period, call SetPeriod(double seconds). FYI this is a minimum. If the code is taking longer than the period to execute, it will wait for the code to finish. Also, call SetPeriod(0.0) to reset it to DS packets.
For # of loops per second, call GetLoopsPerSec() (warning: it doesn’t check for the special 0.0 value that signals DS packet sync. It will try to divide by zero if you call it when in DS sync mode)
Coll thanks! But:
do we have to include additional header files and etc?
THANKS!!!
-Masoug
Nothing extra is needed. Those functions are inherited with the IterativeRobot class
