In cases where we want to produce a ppl command (for a dynamic path from points that are not previously known) in the initialization method of one of our commands, how should we best execute that command. We started with:
ourCmd {
initialization() {
make points;
make path;
cmd = AutoBuilder.followPath(path);
cmd.schedule();
end(...) {
cmd.cancel();
we the bind:
joystick.a().whileTrue(new ourCmd());
Which worked for a while, but after a number of updates fails to call end() when button A is released. The followPath command will run to completion regardless of releasing the button. This is not good for testing with things go awry. So we have shifted to:
ourCmd {
initialization() {
make points;
make path;
cmd.initialize();
execute(){
execute();
end(...) {
cmd.end();
isfinished {
return cmd.isfinished();
This works, but… I feel that there should be some better way. I don’t see an AutoBuilder.followPath(Supplier) method.
What is the best practice for doing this?
Thanks,
Rich
