How to acquire a full Control Panel worth of vinyl
Hey all, happy kickoff 2020!
For testing purposes, I’ve been trying to track down where to get more of the vinyl that will be used on the field this year, enough to make a full double sided Control Panel wheel. I understand based off the KOP list the samples came from TurnOne Graphics, but I’m not 100% sure if that’s the easiest route to acquiring more from. Anyone find a solution to this?
Thanks!
Check with your local sign/graphics shops. They will probably have the same type of vinyl and could even print and cut you pieces if you give them the graphic and what scale you need.
I know andymark sells one. Or if you have the capabilities, I get my vinyl from Heat Press Nation
I’m on the Roland GX-24 and Roland SP 300V at the moment. Both are fantastic in their own way but the 300V has so many features that we use. We use the same machine to sell canvas prints, die cut stickers, printed window vinyl and heat transfer all. One thing we did not look at was the computer programs for the plotters that came in. The GX only runs on Cut Studio and at first it’s very hard to get the full hang of. It feels very different from VersaWorks that runs the SP-300V. Both have their ups and downs but in CorelDraw and Illustrator, VersaWorks is much more user-friendly and comes with a printed swatch library plug-in to match the colors.
