How to avoid uploading the build folder when using Github
My tean wants to upload our program project on Github. And l think we shouldn’t upload the /build folder. But when l init the whole folder with git. It seems that it is impossible to avoid uploading the /build folder every time l want to make a commit. Is there any solution to this?
Using a .gitignore should be work for this. The documentation is quite useful
Thanks. Which folder aren’t necessary to be uploaded?
Edit: Is there any solution to generate this file automatically?
When you created the robot project with vscode, it should have included a .gitignore file.
If you accidentally deleted it, you can find it here.
Thanks , l have copied it to my .gitignore. But every time l build my code , it still has some files which can also be uploaded.
.gradle is listed in the .gitignore file, so that folder should be ignored … from now on. But if you originally committed files in that folder to github, before you listed .gradle in .gitignore, they’re tracked until you manually remove them from git.
Thanks ,l have created a new project and replace it with my own /src and it now works perfectly.
I’d recommend reading up on the proper way to use git add and git remove in commits. Can help alleviate stuff like this quickly.
I recommend making sure you commit the .gitignore file to the repo. So that any future clones of the repo will include it.
