How to configure LT RT buttons in commandbase
Hi all,
I am using Logitech joystick.
I am confused. I bound all the joystick buttons in configureBindings function. But I couldn’t figure out how to bind LT, RT and analog buttons to a command.
I can get these data with getRawAxis but I am stuck there.
How can I handle this issue?
You can use a CommandGenericHID object to bind an axis to a command.
CommandGenericHID controller = new CommandGenericHID(port)
controller.axisGreaterThan(axis, deadzone).onTrue(new Command())
If you want to get boolean values of the buttons from this class, you can get the GenericHID controller by doing
controller.getHID() //returns a GenericHID controller
controller.getHID().getRawAxis(axis) //allows you to read raw values of axis
We are using xbox controllers but the idea is the same.
CommandXboxController m_driverController = new CommandXboxController(0);
m_driverController.rightTrigger().onTrue(new ConeInCommand()))
You should be able to do something like:
CommandPS4Controller m_driverController = new CommandPS4Controller(0);
m_driverController.R2().onTrue(new ConeInCommand()))
See the javadoc for other buttons you can bind to:
Here is our code using xbox controllers. Referring to this may help with where to put the above lines of code:
