Hello, I am new to FRC and i am wondering how do i display image feed from a microsoft HD webcam plugged in into the usb port on roboRio to the camera view option on FRC driver station.:]
What language are you programming in?
/http://www.chiefdelphi.com/forums/showthread.php?t=132714
My reply on this thread turned out to not be as relevant as I thought towards OP’s question, but maybe it can help you. DISCLAIMER: This is java-specific. You might want to specify what language you’re coding in.
I found a solution at http://www.chiefdelphi.com/forums/showthread.php?t=132686 turns out there is no need to code if you are using the default dashboard to display the camera view:]
Correct, if you are using LabVIEW.
One more question: do the Microsoft USB camera take less bandwidth than the axis cameras?:]
Hello guys, i just tested the instruction above on the robot, the camera was on but no images appeared on the FRC control panel. How do I solve that problem?
PS: the blue light on the Microsoft HD Camera 3000 flashes twice but turns off after that.
Was the camera plugged in when you booted the roboRIO? If not, I would try that. And make sure you have selected USB HW or USB SW on the dashboard.
