How to do a sleep function?
I know you can’t use it as the entire robot will be unresponsive, but is there any equivalent, as in Button press, then 3 seconds later preform task?
Keep track of the start time in a variable. Use a loop and in every iteration, check if the current time is 3 seconds more than the start time. If it is, you can then do whatever you wanted to do
See Java Timestamp Actions
If you are using Command-Based paradigm, use a command group assigned to the button.
First command in the CommandGroup would be
addSequential(new WaitCommand("Wait for doohickey", 3);
addSequential(new DoTheThingYouWantedCommand());
