I’m using the whileHeld command to get the raw value of the PWM motor. However, the whileHeld command is giving me an error and I don’t know why.
You’re not passing it a command. You want to pass it a
new RunCommand( () -> getRawAndDealWithIt())
It’s called a lambda and it’s how you pass a method as an argument.
What are you trying to do with the raw PWM value?
These are commands, but I’m not sure they are what you are looking for.
https://docs.wpilib.org/en/latest/docs/software/commandbased/commands.html
I’m try to write a program about while held the button, motor run, while released, motor stop.
Aha. You want to put your joystick button in RobotContainer.java. And bind it as follows.
shooterSpinDownC = new InstantCommand(() -> shooterS.spinDown(), shooterS); //create start and stop commands l
//in configureButtonBindings
Button.whileHeld(shooterSpinUpC)
Button.whenReleased(shooterSpinDownC)
Though for a shooter I would use a state machine. Ask me about state machines.
How to orgnaize all motor as a shooter? Use state machines?
In the spirit of being helpful I will leak a portion of our code.
/* Copyright (c) 2019 FIRST. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package frc.robot.subsystems;
import com.revrobotics.CANEncoder;
import com.revrobotics.CANPIDController;
import com.revrobotics.CANSparkMax;
import com.revrobotics.ControlType;
import com.revrobotics.CANSparkMax.IdleMode;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
import edu.wpi.first.wpiutil.math.MathUtil;
import frc.robot.constants.ShooterConstants;
import frc.utility.preferences.NomadDoublePreference;
import io.github.oblarg.oblog.Loggable;
import io.github.oblarg.oblog.annotations.Log;
import io.github.oblarg.oblog.annotations.Log.ToString;
public class ShooterS extends SubsystemBase implements Loggable{
CANSparkMax spark = new CANSparkMax(ShooterConstants.CAN_ID_SHOOTER_SPARK_MAX, MotorType.kBrushless);
private CANPIDController pidController;
private CANEncoder encoder;
public NomadDoublePreference kP, kI, kD, kIz, kFF, kMaxOutput, kMinOutput, maxRPM, RPM, maxError, armThreshold, fireThreshold, stopThreshold;
private enum ShooterState {SPINUP, READY, ARMED, RECOVERY, SPINDOWN, STOPPED};
private int cyclesInRange;
@Log
private int ballsFired;
@ToString
private ShooterState state = ShooterState.STOPPED;
@Log.Graph(name = "ShooterRPM")
private double currentRPM;
* Creates a new sparkMaxS.
public ShooterS() {
spark.restoreFactoryDefaults();
spark.enableVoltageCompensation(12);
spark.setInverted(true);
spark.setSmartCurrentLimit(30);
spark.setIdleMode(IdleMode.kCoast);
spark.burnFlash();
pidController = spark.getPIDController();
encoder = spark.getEncoder();
kP = new NomadDoublePreference("kP", 0);
kI = new NomadDoublePreference("kI", 0);
kD = new NomadDoublePreference("kD", 0);
kIz = new NomadDoublePreference("kIz", 0);
kFF = new NomadDoublePreference("kFF", 0);
kMaxOutput = new NomadDoublePreference("maxOutput", 1);
kMinOutput = new NomadDoublePreference("minOutput", -1);
maxRPM = new NomadDoublePreference("MaxRPM", 5600); //5700 max
RPM = new NomadDoublePreference("RPM", 1000); //5700 max
maxError = new NomadDoublePreference("MaxError", 500);
armThreshold = new NomadDoublePreference("ArmingRPM", ShooterConstants.SHOOTER_RPM - 100);
fireThreshold = new NomadDoublePreference("PostShotRPM", ShooterConstants.SHOOTER_RPM -200);
stopThreshold = new NomadDoublePreference("Stopped RPM", 60);
// set PID coefficients
pidController.setP(kP.getValue());
pidController.setI(kI.getValue());
pidController.setD(kD.getValue());
pidController.setIZone(kIz.getValue());
pidController.setFF(kFF.getValue());
pidController.setOutputRange(kMinOutput.getValue(), kMaxOutput.getValue());
SmartDashboard.putNumber("SetPoint", 0);
@Override
public void periodic() {
/*pidController.setP(kP.getValue());
pidController.setOutputRange(kMinOutput.getValue(), kMaxOutput.getValue());*/
currentRPM = encoder.getVelocity();
updateState();
public void runVelocityPIDrpm(double RPM) {
spark.set(ShooterConstants.SHOOTER_FEEDFORWARD.calculate(currentRPM));
//pidController.setReference(RPM, ControlType.kVelocity, 0,
// ShooterConstants.SHOOTER_FEEDFORWARD.calculate(currentRPM));
public void setSpeed(double stickVal) {
stickVal = MathUtil.clamp(stickVal, -0.8, 0.8);
spark.set(stickVal);
public void spinUp() {
if(state == ShooterState.STOPPED || state == ShooterState.SPINDOWN){
state = ShooterState.SPINUP;
pidController.setReference(ShooterConstants.SHOOTER_RPM, ControlType.kVelocity);
private void updateState() {
switch (state){
case SPINUP:
runVelocityPIDrpm(ShooterConstants.SHOOTER_RPM);
if(Math.abs(ShooterConstants.SHOOTER_RPM - currentRPM) < maxError.getValue()) { //if we are less than maxError over out target
cyclesInRange++; // increment the counter
if(cyclesInRange > ShooterConstants.MIN_LOOPS_IN_RANGE) { //if the counter is high enough
state = ShooterState.READY; //set state to READY
cyclesInRange = 0;
break;
case READY:
if(currentRPM < armThreshold.getValue()){ //if velocity drops below "we might be shooting" threshold
state = ShooterState.ARMED;
break;
case ARMED:
if (currentRPM < fireThreshold.getValue()) {
ballsFired++;
state = ShooterState.RECOVERY;
else if (currentRPM > armThreshold.getValue()){
// if it has dropped below "ball has definitely gone through" threshold
// increment balls fired.
// go straight to RECOVERY
// if it goes back above the armed threshold go back to ready.
break;
case RECOVERY:
// if we are back up to setpt speed,
// go to READY
break;
case SPINDOWN:
spark.set(0);
//pidController.setReference(0.0, ControlType.kVoltage);//set motor to coast mode 0 power.
if (currentRPM < stopThreshold.getValue()) {
}// if motor has stopped moving,
// go to STOPPED
break;
case STOPPED:
//do nothing until further command.
break;
public void spinDown() {
state = ShooterState.SPINDOWN;
public void stop() {
@Log
public boolean isReady() {
return state == ShooterState.READY;
Why do you need the raw PWM value to do that?
