l use WPILib to control my swerve and l want to get the x and y speed of my swerve in auto, how can l do that. In the teleop, it seems that l can get these two values from chassisspeed, but in auto, which uses setModulestates() to control. So, can l get the x and y speed from swervemodulestates. Or , is there any method to convert the swervemodulestate to the chassisspeed again so that the x and y value can ge got?
You can create module states using the swerve encoders and do the transition from module states to chassis speeds and then use the gyro to convert to field-oriented values.
Is this field-relative? How to get the field-relative one?
The function generates robot-relative speeds, you will need to use trigonometry to convert the speeds.
I would start with combining the x and y speed to create your robot-relative speed vector, then rotate to be field-centric using the gyro angle and finally split it again to field-relative x and y speeds.
There is also ChassisSpeeds.fromFieldRelativeSpeeds
that does this for you (by passing the reported gyro angle)
