So I’ve been looking at other team’s codes for inspiration and looking back at some of my own team’s old libraries and im noticing alot of utility classes being used. Whether these be based in a seperate repo or on the main robot code repo itself it includes classes ranging from all sorts of things such as Limelights, Controllers, Pneumatics, etc.
What I was wondering was how would I create my own versions of these? How do I make them original (if possible at all) What should I create them for? If anybody has any ideas/examples I could go off of that would be greatly appreciated.
For my team, I’ve looked at creating a separate utils repo but so far we just have a utils directory that we just copy from robot to robot or I’ll add it to our repo template so it’s already there. We don’t have too many utils at this point so hasn’t been an issue.
Our team uses a custom vendor library called SuperCORE to handle everything you listed and more. This was a lot of work to setup but is very quick and easy to use since we can install it by simply pasting a link in VSCode.
Don’t create them just to create them. If you find yourself reusing a section of code a lot, refactor it into a reusable class or method. Taylor it towards the way you write robot code. But don’t just make a library because you think you need a library.
Very useful. Since it’s a vendor library it’s easy to quickly install and update. It has a few other cool features but for the most part it’s just like a normal vendor library.
