Hello,
I am using the Rev Neo integrated encoder and I am able to read the position value, but I don’t know what units that translates into.
Thanks for any help you can provide.
Hello,
The default position output is in rotations of the output shaft.
You can use .setPositionConversionFactor()
to automatically convert position to your own units like meters.
Thank you! How do I find/calculate the conversion factor for my desired units?
You have to use the gear ratio from your motor to your output shaft. I think the standard AndyMark chassis has a ratio of 10:1. Then you need to calculate the circumference of your wheels. Divide the circumference by the gear ratio to get your conversion calculation.
10.71:1 to be specific for the AndyMark AM14U5 kitbot chassis in its default configuration
