How to make a motor work
So this is regarding a post from a while back, but were still having the same issue. How do you turn on a motor, and link it to a joystick so it can work, i tried what i was told, and went through examples, but they still wont work.
Can you link the previous post? It will help to see what you already tried.
For the basics, you can look here if you didn’t already:
https://wpilib.screenstepslive.com/s/currentCS/m/labview/l/696081-tank-drive-tutorial
100 times this, also if you are using a specific type of motor controller i would recommend looking at there docs as well
Minnesota folks, mind reaching out to these guys? @Ryan_Swanson @Jon_Stratis
Just texted our floating CSA/programming mentor and he should be reaching out shortly!
