I have the 3 servo motors for the arm programmed in the begin vi, I have The second joystick programmed in the teleop vi, and the begin vi:cool: , now what.
Well you need to decide how you want to control your arm
1.buttons?
2.joystick?
3.telekinesis?
You need to give us some details so we can help you the best:D
well it will have 3 degrees of freedom so 3 motors, (telekinisis would be nice:rolleyes: ) but one motor with the x axis, and the other 2 with 2 buttons each.
We already have the arcade drive with the first joystick for the driving part programmed good, we just need the arm:D. I even have the 2nd joystick programmed into the teleop vi, i just need to know how to program the buttons and x axis to joystick.
1-ok, well First you are going to want to pull out the reference for your second joystick
2-Second you need to pull down a Get.vi
3-Third you need to get two unbundle by name functions from the Cluster,Class and Varient section
4-Wire the unbundles to the button and axis output
5-you need to create open.vi’s for three motors (each one set to its pwm)
6-To make the motors move on a button you are going to need a case structure for each motor with the set speed.vi in the case structure set to the speed you want to move it
6-for the axis just wire axis one into a set speed.vi
If you are needing to learn the basics i suggest you watch the videos from here http://www.frcmastery.com/
and this is all in the teleop vi?
Yes, sorry i would post a pic but snowed in without a programming computer
np. by the way, how is your season going?
and on step 6 i am confused, the other 5 i already got.
to get a motor to turn at a certain speed when using a button you put a motor set speed.vi in the true case of the case structure,then wire the unbundled button to the case condition. The false case needs to be a set speed.VI set to what you want the motor to do when the button isnt pressed
wait, so i have step 2 in the 7 steps thing, now what?
can you email me a diagram/picture?
is it the set speed jaguar vi.
and how do i wire the set speed?
Yes, The bundle data (pink wire) from the motor devref needs to be wired to the set speed and the speed value needs a constant in each case
How do I program the drive rev to not be in the first 2 motors for the arm?
And where is the set speed vi
Could you explain what you mean here?
It is in the motor pallet in the WPI robotics Library
Good except we lost a week due to weather!
Yes.
Please explain or send diagram of how to wire it in and outside the of the case structer.
