How to program Xbox Triggers (Java)
I was wondering how to set up the Xbox controller triggers so that I may control the speed of the motors depending on where the triggers are positioned. Thanks for the help!
~Robert Byrd
We have a joysticks class for our Xbox controllers. Uses every button on the controller. Feel free to use whatever you want.
Since the triggers are a double value, you just input that into your motor output. Example:
TalonSRXObj.set(percentOutput, joystick1.leftTrigger);
There are a couple of ways you can do this, if you are using the XboxController class, you can use the getTriggerAxis(Hand hand) method, where hand is either Hand.kLeft or Hand.kRight depending on which trigger you want.
eg, get the right trigger value
  XboxController xb = new XboxController(0);
  double triggerValue = xb.getTriggerAxis(Hand.kLeft);
You can then pass that information onto your motor controller.
eg, if you use a PWM Spark
spark.set(triggerValue);
You’re using public member variables!?!? I won’t tell. :shushing_face:
Haha I’m too lazy. It’s just easier.
