We need help on how to wire the allen-bradley light…someone help please! robot is due today. We need it fast
And we need a better description of what you need. Referring to “that light” might have worked if we could see where you were pointing, or if you had attached a picture of it. Please tell us what light you are talking about.
If you are talking about the diagnostic light, a diagram can be found here
Link is dead, and we need to know where that needs to go if it is a rule, someone help! We need to ship this robot!
Jake et al,
This is not a critical part for you to ship your robot. Just make sure it is included in your shipping crate so that it arrives with your robot. An inspector or other teams will help you at your first regional to get it set up and working. Just be sure you have all the parts…One relay socket for the DIN rail, one relay to put in the socket, one PWM cable and one Amber Diagnostic light.
:yikes:
www2.usfirst.org/2007comp/other/2007_ROBOT_SIGNAL_LIGHT_R1.pdf
There’s the correct link.
thanks !
one word of advice: make sure you use the wiring diagram found in the official FIRST drawings (the link above). Do not use the one in the “Guidelines, Tips and Good Practices” manual. The diagram in the manual is a bit confusing, and the jumper from pin 1 to pin 4 of the digital relay is very easy to miss if you confuse it with part of the coil symbol on the drawing. Several teams have made this mistake, and assumed that their light was not working. When wired correctly (per the 2007_ROBOT_SIGNAL_LIGHT_R1 drawing), it should work fine.
-dave
Does an input signal from the field to the light when plugged into the official field control the power on the light, or should it light up under normal operation? (Re: Turning the bot on in the pits?)
We had an issue with it not lighting up, but assumed it may have been something that was controlled by the field, so didn’t worry too much about it. We had confidence we would get the problem solved the Thursday of our first competition by asking other teams what it was supposed to do/did for them.
(Pesky little light doesn’t need to give us headaches, when we have other more important things to worry about electrically before shipping.) :rolleyes:
I don’t know what diagram we used though, that may just be the problem.
El,
The light functions just like Team LEDs last year. Tether up and enable and you should see the LED on top of the relay and the Amber both light. If you don’t see the relay light up (ours is kind of dim) then you have a wiring problem between the team color connectors and the relay or you have been shipped the wrong relay. If the relay is lighting up but the amber is not, you may have not installed the jumper on the relay from pin 1 to pin 4.
Ok Thanks Al!
No biggie I guess, like I said, just one more thing to tweak Thursday at our first regional.
Thank you!
