How to setup PhotonVision for three cameras (AprilTag camera, ObjectDetection camera, and plain remote vision camera)
Hello
We would like to connect three cameras to our Orange Pi: a global shutter camera for AprilTag processing, a Microsoft LifeCam 3000 for object (note) detection, and a second identical LifeCam for plain remote vision (no processing needed).
Somehow after we plug the second LifeCam and reboot PhotonVision appears to be confused adding numbers in parenthesis after the name of the LifeCam (e.g. (1) (2) (3) after one and (1) (2) (3) (4) after the other).
Some threads from last year suggest that this use case might not have been supported at the time, but more recent threads suggest it might be now.
What is the current support for such scenario? Should it work, or should we simply connect our second LifeCam to a dedicated Raspberry Pi with FRCVision/WPILibPI?
Thanks!
Question somewhat similar to Running two cameras with photon vision for pose estimation - Technical / PhotonVision - Chief Delphi
Two life cams should work in 2024.2.7, but I haven’t personally tested it (I only have one lifecam at home). If it isn’t, can you post “journalctl”/“current run” logs?
Hi, we’re on the team with @gartaud , we do use 2024.2.7 and it’s not working well. How do we find the logs you’re looking for?
We found it, how do you want us to post it? Copy and pasted or an image file?
Hi, I was wondering if you got my reply. Let me know how you want the files, it’s too big to attach here.
Using two (or more) of the same model cameras on PhotonVision isn’t supported on the same coprocessor, hence why it’s giving your camera multiple number tags in the same name as it’s finding the first camera, but then finds another camera with the same name plugged in and then that’s where it’s getting confused.
We ran into the same issue with some Arducam camera modules but used their serial number renaming tool to give our cameras different names from each other.
You could try and see if Microsoft has a tool to do the same thing, or if you can modify the camera name some other way.
This is not true anymore, as of release 2024.2.6/2024.2.7.
We were not able to get two LifeCams reliably work with 2024.2.7.
We ended up reinstalling an old Raspberry Pi with FRCVision/WPILibPI for remote vision next to our new Orange Pi.
