How to start autonomous?
I’m a noob programmer and i was searching for ways to start the robots at the beginning. Any suggestions? like should we start it with the sound at the beggining? :confused:
Are you using the simple robot template or command base template?
Command Base :slight_smile:
You make a new command then call it in robotinit like so:
autonomousCommand = new *insertcommandhere*();
This can make the robot start without, like, pushing buttons?
If you mean that the robot moves/does the command you put in during the autonomous period without you touching the controller, then yes.
