How to trigger a mechanism when a certain setpoint is reached?
How can I make a mechanism trigger when another reaches a certain setpoint?
I want to make an index that activates when the intake reaches a certain setpoint, yet I don’t know how to do it.
Look into command based programming.
You can make a command for the first mechanism and have it finish when the point is reached. After that you can use .andThen to start a second command.
The second command will not run until the first is finished.
Here is another resource that shows how to create and use command based programs with examples.
https://www.frczero.org/programming/command-based-programming/
The information here is…not correct.
A command is a file that contains a set of instructions that can be called by the scheduler.
A command isn’t a file, for starters.
I’m pretty sure this was written by GPT.
Don’t use this. It really doesn’t give good advice, or modern solutions.
If you don’t know what command-based is, then this is a great resource.
Then once you have an understanding (with pictures!) of command-based, then the FRC docs linked above that talk about command compositions will hopefully make some sense.
