How to use joystick button to activate talon?
public class Robot {
private Spark motorFrontLeft = new Spark (0);
private Spark motorRearLeft = new Spark (2);
private Spark motorFrontRight = new Spark (1);
private Spark motorRearRight = new Spark (3);
** private Spark motorTilt = new Spark (4);**
private SpeedControllerGroup motorLeft = new SpeedControllerGroup (motorFrontLeft, motorRearLeft);
private SpeedControllerGroup motorRight = new SpeedControllerGroup (motorFrontRight, motorRearRight);
private DifferentialDrive driveTrain = new DifferentialDrive (motorLeft, motorRight);
private static final Joystick joystick = new Joystick (0);
public Robot () {
  driveTrain.setExpiration (0.1);
public void robotInit () {}
public void teleopPeriodic () {
 driveTrain.arcadeDrive (0.5 * joystick.getY(), 0.5 * joystick.getX());
**if (joystick.getTrigger()==true) {
     motorTilt.set (-0.3);
 } else if (joystick.getTop()==true){
     motorTilt.set(0.3);
 }else {
     motorTilt.set(0);
public void test () {}
Is the code theoretically alright?
Presuming that you want the “tilt” motor only to be active WHILE you are holding the respective buttons down, I don’t see anything amiss. When neither control is active, the tilt motor will be off, which will “Put Sir Isaac Newton in the driver’s seat” - inertia and friction and gravity will rule, plus motor braking if Spark 4 is in brake mode.
