How to use the REV Robotics Power Distribution Block
I’m currently mentoring for the FTC team #12845 and we can’t figure out how to use/hook up the Rev Robotics XT30 Power Distribution Block in combination with the Spark Mini Motor Controllers to our Expansion Hub to run more than four motors. If needed, we can always use a split cable for our drive base, but we were trying to figure out how to use other equipment to run the motors if possible. Thanks!
There is one input in the end that connects to the output from your power switch. The outputs on the top connect to your XT30 powered devices; Rev controllers, Spark controllers, LED Lights, etc.
