How to wire the ethernet for brainboxes sw-005?
My team is using limelight on our robot this year and we got a ethernet switch to run it through. Though our wiring team is having disagreements on how it should wire. One side is saying that we should follow the wiring that is written on the limelight documentation while the other side is saying to wire it in a way that makes sense from the inputs and outputs. What is the correct way to wire the ethernet switch?
The SW-005 is an unmanaged Ethernet switch. It does not matter which port you plug what device into - there is no input or output side.
If OP uses POE to the LImeLight make sure the 12v is injected after the brainbox and NOT into it.
