Human Player Scoring High Note in Speaker
So there is the below rule about Robots not being able to score a High Note in the Speaker. However, we don’t see anything about Human Players Scoring High Notes in the Speaker. Does anyone have anything to disprove this so far?
I do believe you are correct.
Given the flight characteristics, though, it’ll be “interesting” to see if it’s even possible.
Also, Q&A opens Wednesday, please ask if TU#01 doesn’t address this.
HIGH NOTES are not NOTES (as per section 5.7), and as far as I can tell only NOTES are counted as scored in the SPEAKER or AMP. As such, when scored in a SPEAKER or AMP, they are effectively no score from my reading.
Under this, if a HIGH NOTE is scored in either place, it seems like it would likely just be adjusted after to remove the scored NOTE in the FMS.
Still worth the Q&A if the team update doesn’t clarify. But this I believe is the correct answer.
Provided someone reports it.
