Can anyone help? When I try to build or deploy our code we get the following error-
Error 6 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
I think it may have something to do with file naming. The error message indicates that the file that is set in the “Local destination directory” from the FRC Basic Robot Deployment Properties is the cause. We did have earlier issues when we renamed and moved our original project.
What file path shoul the “Local destination directory” point to?
Don’t blindly reinstall. If it’s a pathname change issue, the fix is to find the spot in the build specification that points to the incorrect path and to modify it to point to the proper one.
Make a new project and look at its build spec for an example of what the existing project needs to look like. We had to do that when we moved our code from a Windows XP system to a Vista one, and the “My Documents” folder location is different.
I think I found the correct filepath. I made the change tried to build and got a lot of file collision warnings. I know from reading other threads that seems to be normal…right? At the end of the build it did say the build was complete.
Now, of course the robot shipped so I can’t make sure it will deploy…but…when we get access to our robot again we will need to right click on “FRC Basic Robot Deploy Properties” then chose “run as startup”…right?
I believe the 0.0.0.0 needs to be set in the properties dialog for the cRIO. Right click on the cRIO item in the project window and put the correct IP in. This normally gets filled in by the new project wizard, but this is how to change it later. It is also possible that this is the name of the cRIO in the project and in that case, you change it in the same place.
