Decided to learn Onshape during quarantine and I’m doing an assembly exercise
Edit: ok never mind it decided to work
Click the circle guy with the arrow denoting rotation at the bottom of the mate creation window. That’ll rotate your Fastened Mate 90 degrees.
Yeah, the problem is that i need to rotate it less than 90 degrees
In that case, without context of your assignment, I’d recommend a revolute mate with carefully set angular limits.
Based on the assignment title, it wants the OP to create an explicit mate connector with the desired rotation.
