I installed NI Labview 2019 but Cant find Driver station or RoboRio imaging tool
I finished installing the 2019 Labview after wiping my computer to make sure I got rid of all 2018 software but I can’t find Driver station or the Roborio imaging tool. I followed this guide exactly: https://forums.ni.com/t5/FIRST-Robotics-Competition/Installing-LabVIEW-for-FRC-2019/ta-p/3878802 is there anything else I should have done?
You need to install the FRC 2019 Update Suite. See instructions here: http://wpilib.screenstepslive.com/s/currentCS/m/labview/l/1027502-installing-the-frc-update-suite-all-languages
That is the guide I followed.
There are two separate installers. There is an installer for LabView (which is the guide you linked to), and also a FRC 2019 Update Suite which installs the FRC specific bits including the Driver Station and RoboRIO Imaging Tool.
Do I need to remove everything from the first installation before I do the update suite?
No.
Has there been any progress made? Our team is having the same problem. Also, @Peter_Johnson, where is the other download? I can’t seem to find it.
The link is in the screensteps article I linked to above, under the section “downloading the update”, but here’s a copy of the link: http://www.ni.com/download/first-robotics-software-2017/7904/en/
Check out the force reinstall…
