Hello, I would like to know if anyone has worked with the NavX2 MXP sensor, I am initially trying to test it in LabView, I am not able to do anything with it, if anyone has any test code it would help me a lot.
What I want to do later is that when I press a button, the robot, even if decentralized, centers itself and walks in a straight line.
For getting started with the navX in Labview (such as just reading values from it), I’d start with their getting started section.
For this, I would have a look at the examples found on the Kauailabs website (company that makes the navX). Their rotate to Angle example looks of particular interest in this situation.
It’s been a number of years since I’ve touched Labview, and am hardly a coder to begin with; But if you have troubles understanding/working through the examples, I’m sure some of the more knowledgeable members of this community would gladly help point you in the right directions.
If you just want to verify the sensor is working and properly connected, you can use navXUI on a PC.
I used it, I got the answer but I want a test in Labview, to see how it works
