I want to use 2 strip neopixel but i can use only 1
hi, when i light one strip neopixel (rainbow or one colour) it works, but when i add second strip it doesn’t work and gives me stacktraces error but im sure it right.
Is this off the rio? Now i have limited programming knowledge but I am pretty sure the rio can only handle one strip… we ran ours in parallel this year to combat that issue. Maybe you could try that?
@veg would know more
what is rio
RoboRIO
oh really? im afraid i cant ran parallel, is there a way to get rio to be handle 2
You’d want to connect them end-to-end to have one long strip, which you set different parts of to different patterns.
they on robots opposite sides
is rio cant handle 2 :cry:
Correct, the RIO can only handle one. But a really long daisy chain should work.
okey i’ll do it
am i need to make a different on code?
If you want the 2 strips to look the exact same you could run them in parallel electronically
I can confirm that the rio only has one LED driver on board, therefore only one PWM port can be used to control LED’s.
