We’re trying to send data over I2C to an Arduino. Trying to figure out what the appropriate Python data type would be for the I2C.writeBulk() method.
We appear to be connecting successfully to the Arduino and getting a message received, but are having difficulty with the data contents of those messages.
We are creating the I2C object successfully (the Arduino is listening on address 100):
Buffer isn’t a type in python 3, it’s a protocol that objects can implement. Common types that implement the buffer protocol are bytes (but not strings), bytearray, numpy arrays, and memoryview.
Thanks for the tip on memoryview; that was the trick, and we got it working. Here’s our working code:
self.myArduino = wpilib.I2C(wpilib.I2C.Port.kOnboard, 100)
command = 1
# note that bytes takes an array; in our case we are sending just a single int byte
if self.myArduino.writeBulk(memoryview(bytes([command]))):
Thanks very much for this heads-up about the onboard I2C port. We haven’t seen that hanging problem, but it sounds unpredictable and catastrophic when it does occur.
We haven’t tried anything on the MXP port, but reading the NI RoboRio doc, it seems like we should just be able to move our SCL/SDA wires over to pins 32 and 34 on the MXP expansion connector (and, of course, switch the wpilib.I2C.Port.kOnboard to wpilib.I2C.Port.kMXP). Sound correct?
Any idea if this same issue might affect connecting the NAVX micro gyro? We had successfully connected it via the onboard I2C port, but the hang issue you linked doesn’t sound like it’s specific to a particular device. But perhaps the NAVX is somehow known not to generate the problem on the onboard port?
As follow-up on the topic of NAVX gyro & I2C, we moved our NAVX micro from the onboard I2C port to the MXP expansion connector (pins 30-GND, 32-SCL, 33-3.3V, 34-SDA) and changed the initialization to reference the MXP port:
