Hello, I don’t recall the name of a particular item but I can describe it.
It is T-shaped that contains a hidden spring. By pushing a button on top, it releases the spring.
The width of this object is about 1.5 inches.
Need a little more detail than that. What is it supposed to do?
It works like a screw, keeping things in place, however, it takes much less time to remove than a screw does.
quick release pin
Is this what you are talking about:
http://images1.mcmaster.com/Contents/gfx/large/90293a113p2l.png
It’s a type of quick release pin and it’s the only thing that comes to mind with such a vague description.
Yes! That is exactly what I’m looking for! Thank you so much!
Long,
Incase you were still looking at where to order these, go here http://www.mcmaster.com/#standard-quick-release-pins/=g25d9w
