Just adding a little about using key way…
It is a nice way if the sprockets don’t have a hub (the section sticking out on the side of the sprocket) on it. It is really easy to do if you have access to milling machine. Just have the machinist mill a slot along the shaft. Then you can easily use a keyway broach set to cut out the key way on the sprocket. So, when you out the sprocket on the shaft, and line up the slots on both of them, they will become a square space where it can fit a square key stock. Of course, you will have to measure out how much you are going to cut away on the shaft and sprocket, but that’s not hard to do.
Drill and tap through is also a good and easy way, if the sprocket has a hub on it. Simply drill through the center of sprocket hub with the shaft inside¡K Then tap it. This is better than using just a pin since the pin will slide out easily.
I am sure no one will recommend doing this¡K but if you HAVE to use a hubless sprocket, and you don’t have access to welding (see below), then you will just have to drill on the side of the sprocket through the teeth (OUCH!), and tap the hole afterward. I am sure there is a rule among engineers against doing this, but so far I haven¡¦t done it and haven’t been warned about doing it…
A Dutchman¡¦s key, if I remember correctly, is simply drilling a hole through the side of the sprocket hub (not through center), and a resulting hole whose center is tangent to the shaft. Then, all you have to do is put a pin through it, and the sprocket will be rotating with the shaft magically! (actually, it¡¦s because the shaft is compressing the little section of the pin against the sprocket¡K I think)
Also, if you have access to welding, then you can weld the sprocket onto the shaft… You will probably need to mill away a chamfer on the sprocket hole for more area for welding…
But if you want the sprocket removable… then you can choose to weld metal pieces perpendicular to the shaft, and bolt the sprocket onto those metal pieces. Circle disks will work as well.
These are some of the easy ways¡K other methods involve cutting the shaft and sprocket hole into different shapes, such as a double D (])¡K
About “locktite”… maybe Lloyd is talking about “tie wrap” or “zip tie” or “cable tie”… Oh yeah, “bar lok” too…
