Hi all,
I’m writing code to lock onto targets, based off of the example two-color tracking code which used servos (but our robot uses a turret instead). It is very intermittent in finding the two colors, except when someone shines a bright light on it. Has anyone had any similar troubles/have any proposed solutions? Here’s a bit of our code which I think is relevant:
// Initialize particle analysis report
memset(&par, 0, sizeof(par));
// Image data for tracking - override default parameters if needed:
// Make PINK the first color because GREEN is more susceptible to
// hue variations due to lighting so may result in false positives
// PINK
sprintf(td1.name, "PINK");
td1.hue.minValue = 220;
td1.hue.maxValue = 255;
td1.saturation.minValue = 75;
td1.saturation.maxValue = 255;
td1.luminance.minValue = 85;
td1.luminance.maxValue = 255;
// GREEN
sprintf(td2.name, "GREEN");
td2.hue.minValue = 55;
td2.hue.maxValue = 125;
td2.saturation.minValue = 58;
td2.saturation.maxValue = 255;
td2.luminance.minValue = 92;
td2.luminance.maxValue = 255;
// Set up debug output:
// DEBUG_OFF, DEBUG_MOSTLY_OFF, DEBUG_SCREEN_ONLY, DEBUG_FILE_ONLY, DEBUG_SCREEN_AND_FILE
SetDebugFlag(DEBUG_SCREEN_ONLY);
// Start the CameraTask
// Possible values for resolution: k640x480, k320x240, k160x120
if(StartCameraTask(framesPerSecond, 0, k160x120, ROT_0) == -1)
printf("Failed to spawn camera task; exiting. Error code %s",
GetVisionErrorText(GetLastVisionError()));
