Import WPILIb Java Class Definitions into Visual Studio Code
Hello. How do I import the WPILib Java class definitions into Visual Studio Code?
Thanks
Darryl
Follow the installation guide for WPILib. Note the installer downloads and installs a separate copy of vscode; you should use this for any robot projects. Then create a project using the WPILib vscode extension.
Peter - thanks for the response.
I used the instructions you referenced several weeks ago, and have created and manipulated several projects since then.
What I am unable to do is get the definition and type definition when I right select a WPILib class.
Peter - it is my error. I was opening the wrong folder in VSCode. I have access to everything that I want. Thanks for the help.
