important question
Hey, if anyone knows where the LED that indicates that the robot is functioning is suposed to go and how it should be connected to the main battery, could you please give a shout out over here.
Are you referring to the panel signal device (formerly called the diagnostic signal light)?
Specifically, see the Robot Signal Light wiring diagram for how to connect it.
