Importing CTRE through Gradle build system without VS Code
Last year’s GradleRIO had the nice ctre() method that imported ctre libraries. I understand that that is not the case this year and you have to do it through installing vendor libraries in VS Code. Currently, I do not have VS Code installed right now and would like to do this completely through gradle if possible.
Right now I just have all the jars in a “libs” folder and import it through gradle but I would obviously want to be able to check for updates without going through a hassle.
For anyone wanting to do this through VS Code, I found this link: https://phoenix-documentation.readthedocs.io/en/latest/ch05a_CppJava.html .
See http://wpilib.screenstepslive.com/s/currentCS/m/getting_started/l/682619-3rd-party-libraries
create a vendordeps folder in your project directory. Then in C:\Users\Public\frc2019\vendordeps you’ll see a Phoenix.json file. Add that to your vendordeps folder, refresh gradle, and you’re good to go
To expand on this, once you create the vendordeps folder in your project directory, you can download the vendor JSON directly from CTRE and put it in that folder. They publish theirs here:
http://devsite.ctr-electronics.com/maven/release/com/ctre/phoenix/Phoenix-latest.json
These instructions are in the GradleRIO README: (and also in screensteps, in the green box)
Thanks. I got it all working. I downloaded the json here: http://devsite.ctr-electronics.com/maven/release/com/ctre/phoenix/Phoenix-latest.json and put it in my venderdeps folder. It seems I looked every place except the GradleRIO readme since that’s the only place I’ve found this info.
To be clear, the online method is mentioned in the tip under
https://phoenix-documentation.readthedocs.io/en/latest/ch05a_CppJava.html?highlight=online#frc-c-java-add-phoenix
But we strongly recommend option 1 (installer). Offline install is meant to guarantee your PC will never need internet to compile your code. I’d hate for your PC to stop building at a competition because something goofy happened to the gradle build system in your project. Or even worst, you have to create a project from scratch in a pinch, but you have no internet.
Theoretically that shouldn’t happen if the VsCode extensions are solid, but we’ve been bit by this during beta - hence the caution.
