Inspection
Now that most teams have had at least 1 inspection the process will be modified slightly.
You robot will be issued a sticker saying you have passed inspection. You will be asked if you have made any changes or alterations since the last time it was inspected.
We will inspect the changes, test size and weight and air pressure. We will give the robot a quick once over to make sure you comply with the rules. We will make a safety check and then put you on your way.
