Install Error - WPILib 2024.3.1 Release
Trying to install the new version of WPILib and VS Code and get error message. Assistance appreciated. I do have the 2023 version running on my laptop - works fine - but thought the update would be useful for 2024…
Error message follows:
System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
—> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host…
—> System.Net.Sockets.SocketException (10054): An existing connection was forcibly closed by the remote host.
— End of inner exception stack trace —
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token)
at System.Net.Security.SslStream.EnsureFullTlsFrameAsync[TIOAdapter](CancellationToken cancellationToken, Int32 estimatedSize)
at System.Runtime.CompilerServices.PoolingAsyncValueTaskMethodBuilder1.StateMachineBox1.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token)
at System.Net.Security.SslStream.ReceiveHandshakeFrameAsync[TIOAdapter](CancellationToken cancellationToken)
at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](Boolean receiveFirst, Byte reAuthenticationData, CancellationToken cancellationToken)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
at System.Threading.Tasks.TaskCompletionSourceWithCancellation1.WaitWithCancellationAsync(CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at WPILibInstaller.Utils.HttpClientDownloadWithProgress.StartDownload() in D:\a\WPILibInstaller-Avalonia\WPILibInstaller-Avalonia\WPILibInstaller-Avalonia\Utils\HttpClientDownloadWithProgress.cs:line 29 at WPILibInstaller.ViewModels.VSCodePageViewModel.DownloadForPlatform(String downloadUrl, Stream outputStream, Action1 progressChanged) in D:\a\WPILibInstaller-Avalonia\WPILibInstaller-Avalonia\WPILibInstaller-Avalonia\ViewModels\VSCodePageViewModel.cs:line 397
at WPILibInstaller.ViewModels.VSCodePageViewModel.DownloadToMemoryStream(Platform platform, String downloadUrl, Action`1 progressChanged) in D:\a\WPILibInstaller-Avalonia\WPILibInstaller-Avalonia\WPILibInstaller-Avalonia\ViewModels\VSCodePageViewModel.cs:line 379
at WPILibInstaller.ViewModels.VSCodePageViewModel.DownloadSingleVSCodeFunc() in D:\a\WPILibInstaller-Avalonia\WPILibInstaller-Avalonia\WPILibInstaller-Avalonia\ViewModels\VSCodePageViewModel.cs:line 349
It looks like something is blocking the vscode download? Are you behind a school firewall or similar?
I’ve had this occur on personal devices on my home network. Have no clue why it happens, but after reboot it’s always resolved itself.
No firewall other than the conventional Windows firewall. The previous version installed fine - surprised that the latest version does not…
Rebooted then tried again to install - same result. Have 112GB storage available so not a space constraint…
