Installed 2024 WPILib_macOS-Arm64-2024.3.1 => Manage Vendor Library not showing up
I installed 2024 WPILib_macOS-Arm64-2024.3.1 => Manage Vendor Library not showing up so I can install 2024 Rev java library files
On Mac OS 12.5.1, 16 GB ram, MacBook Air M1
  1. I deleted 2023 folder ( ~/wpilib/2023)
  2. I installed as instructed 2024 WPILib_macOS-Arm64-2024.3.1.dmg (WPILib Installation Guide — FIRST Robotics Competition documentation )
  3. Started up VS Code and wanted to use WPIlib: Manage Vendor Library
  4. nothing shows up, like the command did nothing. See this video for what I see => https://youtu.be/mlWr83jamwo
  5. I did a reinstall of the 2024 WPILib_macOS-Arm64-2024.3.1.dmg… Still same issue.
  6. Search ChiefDelphi… not finding any post that looks similar …
What is the magic trick to use? :slight_smile:
:magic_wand:
Do you have an frc project open?
I did not have an FRC project open… Is that a requirement?
From 3rd Party Libraries — FIRST Robotics Competition documentation
Vendor dependencies are installed on a per-project basis (so each robot project can have its own set of vendor dependencies).
Without a project open, there’s nothing to install vendor dependencies to.
Thanks :slight_smile: Now working. As a new person the subtlety of “Vendor dependencies are installed on a per-project basis (so each robot project can have its own set of vendor dependencies).” was not obvious to me :slight_smile:
