Interchangeable Bearings on VEX Dog Gears
Does anyone know if the bearings in the VEX/WCP Dog Gears are removable/swappable. Just for context, I would like a round bearing on the 60t dog gear, but their website lists it as having a hex bearing.
Thanks!
Yes, you can pop the bearings out and press new ones in (be sure to loctite them when pressing them!).
EDIT: I was informed that specifically you should use green loctite like the one found here.
Great! Thanks for the help!
