Interrupts
Could anyone help us with Interrupt Code for use with optical encoders? We are placing two of the small, yellow banner sensors next to the wheel, which will be covered in a sheet of paper with alternating black and white stripes. As the wheel turns we plan on detecting the change between black and white, and by comparing the counts for both the left and right wheels, we should be able to program precise turns and straight lines.
I am aware of some of the problems with Interrupts, therefore I only want to increment a counter when the state changes. The Optical sensors are plugged into rc_dig_in03 and 04.
Anyone have any ideas.
I should work if you use this code for the interrupt handlers:
**void** **Encoder_3_Int_Handler**(**unsigned ****char** state)
*// Encoder 3's phase a signal just changed logic level, causing this *
*// interrupt service routine to be called.*
**if**(state **== **1)
Encoder_3_Count **+=** ENCODER_3_TICK_DELTA;
**void** **Encoder_4_Int_Handler**(**unsigned ****char** state)
*// Encoder 4's phase a signal just changed logic level, causing this *
Encoder_4_Count **+=** ENCODER_4_TICK_DELTA;
Adjust ENCODER_3_TICK_DELTA and ENCODER_4_TICK_DELTA per the instructions in encoder.h to get the counts to go in the proper direction.
-Kevin
