We are trying to figure out the difference between having a field element and not having one and which layout we need to use. We have a representation of a power port but are still unsure which layout to use.
Image on the top is for a 2D representation, the one on the bottom is for 3D. I hope this helps a little.
Point of clarification. Top is also for a 3D element where the back of the element has room to be outside the Challenge Space. Essentially, the top is the default layout unless you are space limited. Then, if it’s necessary for the 3D element to sit inside the boundary, the colored zones stay the same depth and the re-introduction zone shrinks.
