I was told that there was a really good paper in interupts. Could anyone point me to that?
Also, any docu about how to use/write to EEPROM would be much appriciated!
Ultamently i want to create a command line interface for my robot. This will be complete with the ability to tweak settings and perhaps script autonomous code on the fly. A status screen would also be very nice but for that i would need to understand how VT100 works.
I have EEPROM code that works with the robot controllers. A version that will work with the 2004/2005 controllers can be found here: http://kevin.org/frc/2005/. I’ll release a version for the 2006 controller soon (It’s done, but I want to do some testing).
Well, the new camera menuing code should give you some ideas.
From camera_readme.txt:
Since the IFI terminal is somewhat restrictive, you might
consider using one of the free high quality terminal emulators
available. TeraTerm Pro ([http://www.ayera.com/teraterm](http://www.ayera.com/teraterm)) and
PuTTY ([http://www.chiark.greenend.org.uk/~sgtatham/putty](http://www.chiark.greenend.org.uk/~sgtatham/putty)) are
a few examples. If you dive into the existing code or create
your own custom menus (as I hope you will), you might consider
writing code that will exploit the capabilities of a good
terminal emulator. To get started, do a google search on the
phrase "terminal escape codes".
You’ll find my interrupt template code for the 2004/2005 controller here: http://kevin.org/frc/2005. It should work just fine with the 2006 controller, but I haven’t tried compiling interrupts.c/.h for the new controller so your mileage may vary.
