Question was do we got “old fashioned” like every year that means Aluminum Frame, Andy mark gear boxes etc etc. Or do we finish the off season 3d print project and go plastic. Well at least for the first couple of weeks we are going to pursue both paths and see what is going to happen. The following are some pics of the 3d Printied project
When all 4 motors and wheels are mounted. (currently 1 motor and 2 wheels are mounted) we will talk a little less than 30 lb including the electronics (roborio, Talon srx etc). Right now the top plate is hardboard in the final version once we know where everything goes it will be lexan. If we want to shave some weight we could replace the churros with 1/2 in PVC hex shafts and if we want to up the weight we replace and maybe add some steel hex shafts in the hex holes. Well we will see how the project goes.
